Removing air vent
cobbdu1
Removing air vent
Post by cobbdu1 » Sat Feb 01, 2020 12:12 pm
Is anyone able to help me by giving me some sort of idea as to how to replace an air vent please? It’s one of the vents in the middle of the dash. I have a replacement, I just need to fit it.
Re: Removing air vent
Post by g8dhe » Sat Feb 01, 2020 1:42 pm
Can you not work out from the replacement how its held in place ?
Someone else suggested that the sides need to be pushed inwards as I understood it, so I presume there are pins of some sort (plastic extrusions?) that pop into holes in the dashboard itself ?
cobbdu1
Post by cobbdu1 » Sun Feb 02, 2020 3:57 pm
I’ve removed the vent, and broke it in doing so. I don’t mind that but I don’t want to replacement to got he same way. Unfortunately, having spent 10 minutes on getting the replacement in I’m not convinced it is going to work.
Alkers
Post by Alkers » Mon Feb 03, 2020 5:12 pm
viewtopic.php?f=3&t=28025&hilit=dash+vent
I did something similar with a couple of cable ties, you just need to be careful that you don't put too much force on any one part of hte vent or it will snap
wooden wheel
Post by wooden wheel » Wed Feb 05, 2020 1:21 pm
If I remember correctly, theres a round locating lug on one side. You need to put the vent into the housing on an angle, try and line up the lug and then pull back the other side until it clicks onto place. A bit fiddly, but easier to do than describe !!!!
木の車輪
ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐן ǝɥʇ sı sıɥʇ
