dickie seats
nickhobson25
dickie seats
Post by nickhobson25 » Mon Jan 27, 2020 8:46 pm
evening
we have a 2003 2L bongo Aero city runner and wanted to fit some Dickie seats to the back of the driver/passenger seats but can't see an obvious fixing point which matches the holes in the dickie seats. Any clues or do they only work on certain models?
Re: dickie seats
Post by g8dhe » Mon Jan 27, 2020 10:20 pm
Have you lifted the carpet and looked underneath ? They used to be on all the versions, but if not fitted then the carpet wasn't cut so hides the holes as the nuts are fixed into the chassis on all the ones I've seen.
nickhobson25
Re: dickie seats
Post by nickhobson25 » Mon Jan 27, 2020 11:23 pm
Fantastic! Yep lifted the carpet and bolt holes there. Just need to get the bolts.
Winnie-bongo
Re: dickie seats
Post by Winnie-bongo » Fri Feb 07, 2020 12:31 am
You just need M8 bolts as I am using M8 allen bolts to hold my sub box platform in place in the dickie seat mounting holes.
BromGo
Re: dickie seats
Post by BromGo » Mon May 19, 2025 3:46 pm
Can anyone advise the length of M8 needed?
Thanks!
Re: dickie seats
Post by g8dhe » Mon May 19, 2025 4:04 pm
The part number is 90786-0825B but a Google search doesn't come up with any dimensions only sites with them for sale ....
Re: dickie seats
Post by Bob » Tue May 20, 2025 12:53 pm
Without removing one I would guess about 12mm.
BromGo
Re: dickie seats
Post by BromGo » Tue May 20, 2025 1:59 pm
I tried a few and 25mm was about perfect. 40mm fit but it’s a lot of tightening and sticks out the other end.
Next question… is there a way of tightening or otherwise stopping the seat from folding all the way down? I know they are technically footrests but very easy to fold with any amount of weight. Maybe it’s the two I bought from bongospares or I’m doing something wrong but fairly useless seats.
The stopper (1) moves around to the small bump - and a small amount of force pops it over (2) at which point the seat has folded down on itself.
https://imgur.com/a/JBp8sng
Re: dickie seats
Post by g8dhe » Tue May 20, 2025 2:39 pm
Push the front seat fully forwards and backrest to the screen and then flip the footrest over and it becomes the dickie seat!
BromGo
Re: dickie seats
Post by BromGo » Tue May 20, 2025 3:08 pm
ahhh that makes a lot more sense. I was thinking to disassemble the mechanism and stick a long bolt where that bump is. thanks!
