No power in rear socket
Gripped
Post by Gripped » Fri Dec 27, 2019 7:37 pm
Hi all
There's no power in the rear socket (ciggy lighter). Our Bongo has has the original inverter and 2 pin socket also, but there's no power to any of it. The front ciggy lighter works fine, so it's not the main fuse (fuse 8 ). Plus the fusible link seems to be intact. I've tested the incoming connector blocks but no power there either.
Any ideas?
Thanks in advance. :)
Re: No power in rear socket
Post by g8dhe » Fri Dec 27, 2019 8:34 pm
The only connectors in between the fuses and the sockets are the larger loom connectors so its unlikely to be them X-05 and X-15
Gripped
Post by Gripped » Sat Dec 28, 2019 6:59 pm
Thanks Geoff.
I'll try and work out which module is at fault.
jimmo62
Post by jimmo62 » Sat Dec 28, 2019 8:18 pm
Does the rear socket also have the fusible link built into the rear of the socket? - if so it could be that
Gripped
Post by Gripped » Sat Dec 28, 2019 8:52 pm
Hi. Yes the fusible link seems OK. There doesn't seem to be any power on the incoming wiring. So will check the loom. Front ciggy is fine.
OtleyTheCatbus
Post by OtleyTheCatbus » Tue Jul 21, 2020 8:39 pm
Same has happened to me tonight. Everything working fine except the rear sockets (USB, ciggy, 13 amps) all gone. Fridge, water pump, blinds, everything else all still working fine. I've tried following the wires but it is all hidden in the conversion and I'm not keen on pulling things out until I've exhausted easier tests... Gripped - did anything work for you?
cwilliams255
Post by cwilliams255 » Wed Jul 22, 2020 10:25 pm
As I’m now the owner of gripped’s bongo I can answer and the answer was to run a new live and earth. I’ve since connected them to my other 12v sockets circuit now it has my conversion in
