Cabin light in AFT
cobbdu1
Cabin light in AFT
Post by cobbdu1 » Sun Dec 22, 2019 9:33 am
Just realised how poor our cabin light is. It works, but is weak. Would a replacement bulb help?
Re: Cabin light in AFT
Post by g8dhe » Sun Dec 22, 2019 10:14 am
Quite often yes, the old fluorescent tubes do get a bit dim. Depending on which type of light, early models had a straight tube later had a "U" tube, replacing them can be a problem. For the straight type, tubes are still available and also there are direct LED replacements, for the "U" tube the original replacements are expensive and there isn't a direct LED replacement you need to install LED COB panels like http://www.g8dhe.net/bongo_images/repla ... cent_tube/
cobbdu1
Post by cobbdu1 » Sun Dec 22, 2019 10:32 am
Thank you. It’s a straight type so I should be able to replace.
Gripped
Post by Gripped » Sun Dec 22, 2019 6:02 pm
Yep, we replaced our straight fluorescent tube with an LED direct replacement. It made a big difference.
cobbdu1
Post by cobbdu1 » Sun Dec 22, 2019 8:03 pm
Does it consume less power from the battery too? We don’t have a leisure battery so power is precious.
Post by g8dhe » Sun Dec 22, 2019 9:37 pm
cobbdu1 wrote: Sun Dec 22, 2019 8:03 pm Does it consume less power from the battery too? We don’t have a leisure battery so power is precious.
Not as much a power saving as you might expect as internally there is an inverter to get to the right voltage for the LED's so any possible efficiency with the LED's is lost in the tiny inverter transformer :-(
cobbdu1
Post by cobbdu1 » Sun Dec 22, 2019 9:43 pm
Okay. Thank you.
