Reading throttle position sensor voltage
Timandclaire
Post by Timandclaire » Mon Nov 25, 2019 3:57 pm
Short of removing some insulation or sticking pins through the insulation is there an easier way to get voltage readings from the tps?
Any ideas welcomed
Re: Reading throttle position sensor voltage
Post by g8dhe » Mon Nov 25, 2019 4:06 pm
Insert thin pins into the rear of the connector at the ECU to make contact with the wire/pin inside.
