underbonnet fuse box
Posted: Mon Oct 14, 2019 5:47 pm
by turfite9999
Hi Bongo buddies hope you all keeping well
I was wondering how hard is it to fit a under bonnet fuse box. On my ABS fuse a blade is missing so only one connection for the fuse.
Any help will be appreciated. Thank you
turfite9999
Re: underbonnet fuse box
Posted: Mon Oct 14, 2019 6:05 pm
Which fuse has lost its connector ? Whats happened to it ? Is the wire still there ?
Posted: Mon Oct 14, 2019 6:08 pm
by turfite9999
its 14 the ABS no it's the blade thats missing g8dhe the one you show highlighted the big one
Posted: Tue Oct 15, 2019 9:18 am
Slightly confused then;
The BLADES are the parts on the fuse, if one is missing then replace the fuse.
The fuse connector (socket) is mounted in the fuse holder, and has the wire for the fuse terminated on it, if it is missing then what has happened to it and where is the wire that terminates on the connector ? As without the wire your not going to get very far ....
Posted: Tue Oct 15, 2019 10:02 am
by turfite9999
Thanks for that Geoff
Its not the fuse its the blade coming from the fuse box that the fuse goes into. Dont know about the wires though I may have to take apart.
Turfite
Posted: Tue Oct 15, 2019 2:36 pm
by turfite9999
Hi again trying to send you a photo but cant seem to resize image sorry
Posted: Tue Oct 15, 2019 3:37 pm
Ah thinking about it those fuses are females with the connector on the fuse end and the blades inserted in fuse block of course.
So is that one or both the blades are missing in the block ? They are might have been forced down if someone has tried to force a fuse in, the block can be released with the nuts at the ends.
Posted: Wed Oct 16, 2019 4:32 pm
by turfite9999
Hi Geoff trying to send you photo but even resizing dosnt work if I had your email that may work thank you anyway
Posted: Fri Oct 18, 2019 2:47 pm
by turfite9999
Hi geoff I hope you get this pic please let me know thank you
Posted: Fri Oct 18, 2019 2:48 pm
by turfite9999
it looks like you could just slot a blade in
Posted: Fri Oct 18, 2019 3:06 pm
by Bob
Could it have pulled out with the fuse and still be stuck inside it?
Posted: Fri Oct 18, 2019 4:08 pm
by turfite9999
possible bob just never noticed
