Add on question.... anybody else have a wife up there with a bladder the size of a peanut... and if so, what do they do when nature calls???
 First trip, lots of learning and adapting to be done! All a bit trial and error!
 If its an original factory AFT roof the material should be impervious to water and no proofing needed. Usual cause of water on inside is condensation due to humid air (breath etc) contacting cold surface. For that, ventilation and or an insulating internal liner or an external cover should sort it. Or it may be there is a leak where tenting joins frame but that would not typically cause all over moisture on the tent interior.Stevievee wrote: Sat Sep 28, 2019 8:56 am We are away for the first time in our new bongo, 2 nights in the Yorkshire Dales... It rained last night, blowing into one side of the aft tent, now, the morning after it is wet to the touch on the inside. We didn’t get wet through the night, but after reading other posts on here, it should be fully waterproof. My question is (as obviously our Bongo isn’t) can it be sprayed with something to re-waterproof it?
Zip covers seem fine, after closer inspection, looks like the stitching underneath this. Will look at covering with tape! Thanks.g8dhe wrote: Sat Sep 28, 2019 9:52 am Are you sure the Zip flaps were covering the zip ? They have a habit of getting creased up leaving the zip exposed, if all the moisture starts from the zip area then suspect that might be the problem, otherwise on some of the tents there is a little area at the rear where they are stitched thru the plastic, we covered those areas with a covering of the repair tape.
