electric blinds
Bongolia
electric blinds
Post by Bongolia » Sun Sep 08, 2019 4:58 pm
Can anyone tell me what needs to be done to safely enable elec blinds to be operated with ignition key removed please.
Re: electric blinds
Post by g8dhe » Sun Sep 08, 2019 5:14 pm
Add a leisure battery with Split Charge Relay and swap loom to move the circuits over.
Re: electric blinds
Post by Bob » Sun Sep 08, 2019 6:01 pm
Yes, or gently push/pull to opreate, this won't hurt. :wink:
Bongolia
Re: electric blinds
Post by Bongolia » Sun Sep 08, 2019 6:32 pm
Got the first two but what loom and how?
Re: electric blinds
Post by g8dhe » Sun Sep 08, 2019 6:49 pm
A swap loom is 4 wires and a new fuse box, that connects to the LB, the 4 wires (loom) go to the original fuse box and you pull the 4 fuses, which includes the blinds and put the wires into the lower slot as below, this transfers those circuits across to the LB and are now permanently powered from the LB.
Bongolia
Re: electric blinds
Post by Bongolia » Mon Sep 09, 2019 12:22 am
Got it ,thanks.
