Original Kitchen / Half Seat Rails
Big_Al
Post by Big_Al » Tue Aug 13, 2019 7:30 pm
Hi all,
This is my first, but I'm sure not my last, post!
I've just picked up my first Bongo and it is fitted with an original kitchen pod and to maximise the interior space the guy i bought it from has turned the bench seat to face the rear. I quite like this arrangement however this renders the two three-point seatbelts useless so the bench, when facing to the back, has the lap belt only.
If I'm going on a journey and intend to take a few passengers It may be useful to spin the bench seat to the front so, before i start unbolting things, does anyone know if its possible to slide the seat runners off of the rails when the japanese kitchen pod is installed? The rail seems to be rather close to the pod and if it's a case of having to remove the pod to just take the runners off then I'll give it a miss!
Thanks in advance
Re: Original Kitchen / Half Seat Rails
Post by Bob » Tue Aug 13, 2019 8:25 pm
Welcome to BF.
It's possible that the rails have been modified to take the seat either way round. [-o<
If so it's just a case of unbloting the seat from the runners and turning it round. This is worth a try before you do too much else but bear in mind the seat is flippin' heavy so best to enlsit the help of a burley pal. :wink:
It will sit back on the runners so it's a case of 'does it lock facing the other way'.
