ABS light on
Alacrity
ABS light on
Post by Alacrity » Wed Aug 07, 2019 11:55 am
My Bongo has been stood for most of this year with moving or being started as all. I need to use it this weekend but for various reasons I was only able to start it yesterday & the ABS light is permanently on from the moment it is switched before it is moved. There appears no issues with the wiring to the 4 wheel sensors, all have been disconnected, check & re connected with electrical cleaner used. Battery was disconnected for 10mins but nothing has changed. Battery has never gone flat as it is trickle charged by a solar panel.
Does anyone a) have any thoughts & b) know how to get the fault codes out & what they mean?
Bit worried as it needs an MOT before I go!
TIA Geoff
Re: ABS light on
Post by Ian » Wed Aug 07, 2019 1:18 pm
Is it a pre-99 Bongo? Is there a diagnostic box in the passenger footwell?
Re: ABS light on
Post by g8dhe » Wed Aug 07, 2019 1:19 pm
To get the error codes see this link the ABS codes are at the bottom, last table http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
Alacrity
Re: ABS light on
Post by Alacrity » Wed Aug 07, 2019 2:51 pm
Brilliant, many thanks. What is the method of clearing down codes for ABS?
Alacrity
Re: ABS light on
Post by Alacrity » Wed Aug 07, 2019 4:22 pm
Plot thickens, I have code 55 - not on the list :?
al & chris
Re: ABS light on
Post by al & chris » Wed Aug 07, 2019 5:25 pm
Alternator had gone on ours when ABS light came on.. Check that battery is charging when engine running.
Re: ABS light on
Post by teenmal » Wed Aug 07, 2019 6:00 pm
It would be worthwhile giving the vehicle a run, applying the brakes regularly ( jabbing ).
Re: ABS light on
Post by g8dhe » Wed Aug 07, 2019 7:05 pm
I think you will find that on Ignition on it self tests, and displays any error until switched off again.
Alacrity
Re: ABS light on
Post by Alacrity » Wed Aug 07, 2019 8:11 pm
Sorry chaps, bum steer there, I went & read it myself & got code 11 - right front wheel sensor. So a few tests tomorrow - hopefully just a sensor which is simple to sort out.
It has been driven for 10 miles but the light is on as soon as you start so it has to be electrical somewhere.
Alacrity
Re: ABS light on
Post by Alacrity » Tue Aug 13, 2019 1:26 pm
Thanks for the help, (bloody expensive) wheel sensor sorted it.
