Diagnostic Tool Help
junglist
Post by junglist » Tue Jul 30, 2019 7:00 am
Hello there...
I'm trying to determine whether a diagnostic tool will work on my 2002 2.5 diesel.
The connection looks like this, which I believe is an OBD1 17 PIN type:
http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
Will this tool [1] work with a suitable adapter [2]?
[1] http://www.diagnostic-world.com/pages/m ... 105904.cfm
[2] https://www.ebay.co.uk/itm/For-Mazda-OB ... 2219670942
Thanks!
Re: Diagnostic Tool Help
Post by g8dhe » Tue Jul 30, 2019 8:13 am
As your a 2002 version vehicle you may have a OBDII connector already existing, if so its located under the dashboard to the left of the steering wheel.
junglist
Post by junglist » Tue Jul 30, 2019 9:43 am
Thanks for your suggestion but no OBDII unfortunately.
Post by g8dhe » Tue Jul 30, 2019 11:47 am
I tried a couple of adaptors like you showed but neither worked, I think there may have been a version where the OBDII signal protocol was used on the old style plugs, but the ECU's on mine didn't provided the signal and so the straight adaptor plugs wouldn't work.
junglist
Post by junglist » Tue Jul 30, 2019 4:49 pm
Ok, thanks for your help.
junglist
Post by junglist » Tue Mar 03, 2020 10:28 am
Resurrecting my post, I found this Snap-on KB [1] and purchased items [2] and [3] for use with their Solus Pro Scanner (which a mechanic friend has).
Trying to read the codes, I get 'no connection' consistently. The vehicle ignition is on and the lighter socket has power for the Snap-on power cable [3].
Has anyone seen or tried this?
[1] https://www.snapon.com/Diagnostics/US/K ... hicles.htm
[2] https://shop.snapon.com/product/Scanner ... AA0355L53A
[3] https://shop.snapon.com/product/SOLUS-E ... AX0066L10B
Kirsty1330
Post by Kirsty1330 » Wed Mar 04, 2020 8:11 pm
Not sure any of the scan tools with adapters will work but the diagnostic fault codes can be read fairly easy using a short wire (when you get your head around the flash sequence)
I’ve just had a recent issue with one of my Bongo’s so it’s all still fresh in my head if you need any advice.
nth
Post by nth » Thu Mar 05, 2020 4:52 pm
I tried it with my Bosch KTS & a Mazda to 16 pin OBD adaptor. It wouldn’t communicate at all either.
95 2.5d 4WD AFT
