Alternator output
Russell Jupp
Alternator output
Post by Russell Jupp » Tue Jul 16, 2019 9:53 am
Morning all,
quick question…..
1995 Freda 2.5 TD has a slightly low output from the alternator….
12.6v ignition off
12.8v engine at idle
13.5v at 2500rpm
No warning lights in dash.
I was expecting to see 14.5v
It has a leisure battery, split charge relay, swap loom and a solar panel for the leisure battery.
Test was performed with leisure battery isolated.
Does this suggest a failing alternator?
Russ
The key to life: Fast bikes, fast cars, fast women. And a Bongo.
Re: Alternator output
Post by g8dhe » Tue Jul 16, 2019 9:59 am
It doesn't bode well for the alternator, but do make the voltage measurement at the alternator itself in-case you have a dodgy connection earth/output between the alternator and the battery.
