Is there a vacuum hose diagram for the early Bongo anywhere? Also, I have a solenoid which isn't pulling the throttle on starting. It looks like the very front (white) one is the culprit, but the second one ?...is that the one operating the increase in revs when the A/C cuts in? I presume that the rear two solenoids are for the EGR. As I removed the EGR completely, can I dispose of the rear two, or are they essential for the running of the ECU, which will still signal?
Vacuum hose diagram
- helen&tony
Vacuum hose diagram
- helen&tony
Re: Vacuum hose diagram
Thanks for that Teenmal....Yes, I had checked lushprojects...My version seems to have that missing???...I just double checked ??? ...Weird
Search for this old post helen,
Search cold and start and solenoids post by good old member - jaylee. It goes on for three pages about the solenoids and how they work
- helen&tony
Thanks Ady...I'll take a look...I'll sort this out when the new solenoids get here
