What are these brackets on the roof?
BongoSanj
Post by BongoSanj » Wed Jun 26, 2019 11:06 pm
I've just bought a Ford Freda. And I haven't figured out what these brackets are? The previous owner didn't know either.
There is a small TV/DVD unit inside but the tv aerial input doesn't work, (the DVD does apparently, not tested it). If its for a TV aerial I don't know why there are 2.
They're only on the driver's side.
I'm trying to avoid removing the trim to trace the wires.
Any ideas much appreciated.
Re: What are these brackets on the roof?
Post by g8dhe » Thu Jun 27, 2019 3:11 pm
Because it can be rather mountainous in Japan its normal to fit diversity aerials for TV/Radio so that which ever aerial or combination of aerials give the best signal is fed to the receiver. Hence its quite common to see several often 4 mounts around the vehicle. Totally useless in this country so you can remove them and the associated wiring, which is usually excessive ion length :-)
BongoSanj
Post by BongoSanj » Sat Jun 29, 2019 10:06 am
Ah! Right. Thanks for that. Will probably remove them.
