Read a number of old posts on this subject with interest, some locked, after doing a search on ‘brake fluid’ and ‘brake inspection’ and not coming across much on the forum in recent years. Wonder why no recent updates / thoughts on this.
Bought my 2WD 2.5TD '96 AFT bongo earlier this Spring via Private Sale from last owner who had it serviced annually for last 2-3 years and did only a couple of 1000km a year. Reasonable previous service history (receipts) with most main items done in last 5,000km; filter changes, diff oil change, timing belt and water pump, new radiator and antifreeze. And I have done 2k km this spring since purchase, and she starts, drives, handles, and brakes well.
One of the main things I could not see on the history was details of brake fluid checks / change and pads/ discs status.
So, rather than the hassle and risk of taking all 4 tyres off myself, this week (after addressing last year’s cill welding advisories and getting it past this year’s MOT at specialist bongo garage), I took up the offer of a ‘free no obligation brake system check and report’ from my local boys in blue; you know them of the ‘you can/can’t get better’ (delete as appropriate) fame. I also have one of those cheap DIY brake fluid testers (resistance pens) which suggested a <1% moisture status (i.e. good) before I took it in – but I don’t put too much trust in those.
So what did the free 1 hour inspection and report tell me:
1) Brake pads on front are new. So must have been changed last year by last owner.
2) Disc pads on rear are 18mm which they told me is borderline worn apparently – so due.
3) Nearside rear diff seal is leaking onto rim of disk – needs addressing. Puzzling.
4) Advisory: All calliper bleed nipples are corroded – so could possibly snap.
5) Brake fluid (assumed DOT 4, but possibly DOT 3) boiling point tested at 155 deg C – so low and showing signs of moisture ingress and hence need for replacement. Was quoted £40 for a BF change.
6) Master cylinder, servo, hand brake all OK
7) Tyres all relatively new, though starting to show signs of perishing due to low mileage in last 3 years.
So, that was it. An hour later, tyres back on, a free cup of coffee from the vending machine (£1 into the donation jar) and off I drove.
Any thoughts from you bongo-experienced lot on the above report list?
kbg
- Board index Bongo Fury Techie Stuff
- Search
- It is currently Thu May 21, 2026 4:24 am
- All times are UTC+01:00
Brake Fluid / Brake Inspection
- kandabongogirl
- Bongonaut
Post by kandabongogirl » Sat Jun 22, 2019 12:09 am
23 year old salt and pepper AFT who loves a twerk to a kandabongoman tune.
Jump to
- Using The Bongo Forum
- ↳ Terms & Conditions
- ↳ Guidance
- ↳ FAQs
- ↳ How to Contact Us
- Bongo Fury
- ↳ Techie Stuff
- ↳ Bongo Chat
- ↳ Breaking Bongos
- ↳ Admin & Club Matters
- ↳ Bongo Camping Equipment
- ↳ Pimp My Bongo
- ↳ Was It You?
- ↳ Off Message
- ↳ Group Buys
- ↳ Bargains!
- ↳ Small Ads
- ↳ Bongoing with Children
- ↳ Insurance
- ↳ Campsites
- ↳ Bongo Furry!
- ↳ Going Abroad
- ↳ Bongo Bash 2024
- ↳ Bongo Bash 2023
- ↳ Bongo Bash 2022
- ↳ Bongo Bash 2021
- ↳ National Bongo Day 2020
- ↳ Bongo Bash 2019
- ↳ Bongo Bash 2018
- ↳ Bongo Bash 2016
- ↳ Bongo Bash 2017
- ↳ Bongo Bash 2015
- ↳ Bongo Bash 2014
- ↳ Bongo Bash 2013
- ↳ Bongo Bash 2012
- ↳ Bulgaria 2011
- ↳ Bongo Bash 2011
- ↳ Bongo Bash 2010
- ↳ Bongo Bash 2009
- ↳ Poland 2008
- ↳ Bongo Bash 2008
- ↳ Bongo Bash 2007
- UK Groups
- ↳ Scotland
- ↳ North West
- ↳ Yorkshire & North East
- ↳ Wales/Cymru
- ↳ West Midlands
- ↳ East Midlands
- ↳ Eastern Counties
- ↳ London, Kent & Sussex
- ↳ South Wessex
- ↳ Devon & Cornwall/Kernow
- ↳ Rest of the West
- International Section
- ↳ International
- ↳ Ireland
