Leisure Battery Fitting
Raggy37
Post by Raggy37 » Mon Jun 10, 2019 10:08 am
Has anyone seen a video or set of instructions (with illustrations) explaining how to fit a leisure battery in a bongo? It would need to be aimed at beginners. Thanks
Re: Leisure Battery Fitting
Post by mikeonb4c » Mon Jun 10, 2019 10:44 am
Raggy37 wrote: Mon Jun 10, 2019 10:08 am Has anyone seen a video or set of instructions (with illustrations) explaining how to fit a leisure battery in a bongo? It would need to be aimed at beginners. Thanks
Karl Baes Chadwick does good kits that I BELIEVE include idiot proof instructions. He can be found on Facebook so you could check with him there.
Post by Bob » Mon Jun 10, 2019 12:41 pm
Are you just replacing a failed battery, or ar you looking to fit from scratch?
If the latter, do you have the tray in place?
Mike is right about Karl, and he will be at Stourport, although I would suggest booking a job this size (if you want him to fit it) rather than just showing up. :wink:
TheNewRooster
Post by TheNewRooster » Wed Jun 12, 2019 9:18 pm
Cheers Lads.
As said, Yes I will be at the bash. I will be selling kits and also supply and fit is available. Booking in is a must.
Thanks again, Karl
I'm Back.... A little older, wiser and a lot calmer.
Raggy37
Post by Raggy37 » Sat Jun 15, 2019 11:55 am
Bob wrote: Mon Jun 10, 2019 12:41 pm Are you just replacing a failed battery, or ar you looking to fit from scratch?
Yes I have a tray in place.
Might contact Karl then.
