Van no power on acceleration ? HELP
Patzy
Post by Patzy » Mon May 13, 2019 6:42 pm
Am stuck in a garage hundreds of miles from home in Northern Ireland and my mechanic is stumped by the problem. The water temp gauge now fixed and OK. Compression check made all around165psi. Engine ticks over fine but behaves like mainn jet blocked on a carbed engine. Unable to get the flash codes.
Any advice appreciated!
Patzy
Re: Van no power on acceleration ? HELP
Post by Bob » Mon May 13, 2019 6:45 pm
Which engine do you have?
Patzy
Post by Patzy » Mon May 13, 2019 8:10 pm
Its a 2 litre petrol.
Bongolia
Post by Bongolia » Tue May 14, 2019 8:50 am
Does the engine rev freely when in park with no misfiring/ popping & spitting back?
Can u post a video of the problem.
Post by teenmal » Tue May 14, 2019 5:42 pm
Has your mechanic changed/cleaned All filters and checked timing .??
Patzy
Post by Patzy » Tue May 14, 2019 7:50 pm
Thank you Bongonauts for your replies but my mechanic discovered the problem today! The cat converter was blocked. So I am now flying and able to continue with my road-trip.
Happy travels Patzy :😃
Post by mikeonb4c » Tue May 14, 2019 7:51 pm
Patzy wrote: Tue May 14, 2019 7:50 pm Thank you Bongonauts for your replies but my mechanic discovered the problem today! The cat converter was blocked. So I am now flying and able to continue with my road-trip.
Yayyyyy great result =D>
Post by Bob » Tue May 14, 2019 7:55 pm
Jolly well done. =D>
