Hi all, just replaced second side w/b seems to me way to go,
after removing wheel/disc and brake calliper, use tuning fork type joint tool
look at btm of back plate there is a slot you can see b/j slide tool in and whack
it only took me 6 or so whack's with club hammer for joint to give. I found it
best not to seperate calliper from carrier, but just remove slider bolts one at
a time to clean and grease. Pushing back pistons is a fiddle but i just use
G clamp and small metal bar across pistons after removing brake fluid cap
with rag around to catch any spill ( pushing back pistons makes b/f rise )
only tools I used were 17/19/21mm sockets with long bar, club hammer
trolly jack, axle stand. I also put new disd's and pads on.
I found putting long bolt back loose then b/j , support other end with
Bongo jack to fit "c " bracket don't tighten nuts fully until van off jack's.
good luck anybody doing this job
I also found using tool upside down better
Les
- Board index Bongo Fury Techie Stuff
- Search
- It is currently Sat May 23, 2026 4:24 pm
- All times are UTC+01:00
front wishbones
Jump to
- Using The Bongo Forum
- ↳ Terms & Conditions
- ↳ Guidance
- ↳ FAQs
- ↳ How to Contact Us
- Bongo Fury
- ↳ Techie Stuff
- ↳ Bongo Chat
- ↳ Breaking Bongos
- ↳ Admin & Club Matters
- ↳ Bongo Camping Equipment
- ↳ Pimp My Bongo
- ↳ Was It You?
- ↳ Off Message
- ↳ Group Buys
- ↳ Bargains!
- ↳ Small Ads
- ↳ Bongoing with Children
- ↳ Insurance
- ↳ Campsites
- ↳ Bongo Furry!
- ↳ Going Abroad
- ↳ Bongo Bash 2024
- ↳ Bongo Bash 2023
- ↳ Bongo Bash 2022
- ↳ Bongo Bash 2021
- ↳ National Bongo Day 2020
- ↳ Bongo Bash 2019
- ↳ Bongo Bash 2018
- ↳ Bongo Bash 2016
- ↳ Bongo Bash 2017
- ↳ Bongo Bash 2015
- ↳ Bongo Bash 2014
- ↳ Bongo Bash 2013
- ↳ Bongo Bash 2012
- ↳ Bulgaria 2011
- ↳ Bongo Bash 2011
- ↳ Bongo Bash 2010
- ↳ Bongo Bash 2009
- ↳ Poland 2008
- ↳ Bongo Bash 2008
- ↳ Bongo Bash 2007
- UK Groups
- ↳ Scotland
- ↳ North West
- ↳ Yorkshire & North East
- ↳ Wales/Cymru
- ↳ West Midlands
- ↳ East Midlands
- ↳ Eastern Counties
- ↳ London, Kent & Sussex
- ↳ South Wessex
- ↳ Devon & Cornwall/Kernow
- ↳ Rest of the West
- International Section
- ↳ International
- ↳ Ireland
