Rear heater controls
Alkers
Post by Alkers » Tue Apr 23, 2019 11:34 am
The temperature slider (analogue) rear heater control is missing the mechanical cable connector in our van. The slider is extremely loose and when I last had the side panels off, there was no cable connected at all.
Hasn't been an issue up until now with the very warm weather, we have AC on in the front but the rear doesn't blow cold at all.
Does anyone know where the mechanical cable connects to on the other end (not the controls) - I would like to manipulate this manually so that the rear will always be set to cold (maybe I'll move it the other way again in winter).
Re: Rear heater controls
Post by g8dhe » Tue Apr 23, 2019 11:51 am
Alkers
Post by Alkers » Tue Apr 23, 2019 1:19 pm
Thanks, I did have a look at that. So Part no. 61-325 is what I have. I can't work out from the diagram where the cables coming out of the front of it connect to?
Post by g8dhe » Tue Apr 23, 2019 2:46 pm
The cables drive 61-A20 and 61-A30 on the second diagram to operate the internal flaps - Link Set Temp & Mode
