AFT ROOF FITTING
1307EYRE
AFT ROOF FITTING
Post by 1307EYRE » Fri Apr 12, 2019 8:46 am
HI I was wanting to fit an AFT roof to my tin top Bongo.Has antbody had this done and what is involved.I was hoping to do this myself with little welding .
stuc
Re: AFT ROOF FITTING
Post by stuc » Fri Apr 12, 2019 11:24 am
I've just done this. I need to get some pics to Ian to upload them.
1307EYRE
Post by 1307EYRE » Fri Apr 12, 2019 11:34 am
If you could give me some pics or advice i would be grateful. I have purchased an AFT roof cut off through window piers and want to know the best way of attaching it.I know its not that straight forward Thanks Adrian in New Forest near Southamppton
ognob
Post by ognob » Sat Apr 13, 2019 7:45 am
Hello Adrian
I’m in Romsey, would be interesting to see it!
1307EYRE
Post by 1307EYRE » Sun May 05, 2019 6:15 pm
i am trying to remove an AFT roof from an old Bongo cut off at the roof pillars to put onto my Bongo.I have stripped out the headlining and removed all the nuts and bolts including the hinges.The problem is that i can't separate the AFT roof from the steel roof.There appears to be a mechanical fixing just above the drivers door position.As the electrics are now disconnected how is it possible to separate the AFT roof from the metal roof without cutting anything>
