Can anyone shed any light..............
Debs and David
Post by Debs and David » Wed Mar 27, 2019 8:41 pm
For the past few days, everytime I come to start the bongo (2 litre petrol) for the 1st 15 - 20 seconds there is a clicking sound, like the indicator clicker, the park light is flashing in rhythm with the clicking, so is the handbrake light, if the door is open that flashes as well, the coolant alarm bleeps in rhythm , and the engine revs is also in rhythm. The coolant is at the right level. Suspect something electrical...........any ideas?
Many thanks
Debs & David
You Need Degas to Make De Van Gogh
Re: Can anyone shed any light..............
Post by g8dhe » Wed Mar 27, 2019 10:41 pm
Sounds like something might be loading the battery rather heavily, do you have an Alarm/Immobiliser system fitted at all ?
Post by Bob » Thu Mar 28, 2019 12:05 am
Or perhaps a very dodgey battery?
Does it struggle to turn over? And could you maybe try a replacement battery?
No great science behind this, just a 'gut feel'. :?
Debs and David
Post by Debs and David » Thu Mar 28, 2019 6:17 am
Yes immobiliser fitted, starts first as normal and battery only 12 months old strange one i know #-o
Debs & David
Post by teenmal » Thu Mar 28, 2019 10:33 am
Probably worthwhile removing and cleaning battery terminals and earth strap to body connection.
Debs and David
Post by Debs and David » Thu Mar 28, 2019 6:18 pm
Thanks all for your advice will start checking things at weekend
Debs & David
Debs and David
Post by Debs and David » Sun Apr 07, 2019 10:17 am
UPDATE New leisure battery sorted :D
Debs & David
Post by teenmal » Sun Apr 07, 2019 10:34 am
Debs and David wrote: Sun Apr 07, 2019 10:17 am UPDATE New leisure battery sorted :D
That's strange , the leisure batter should not affect the starting of the vehicle unless it is not wired independently with a relay from the SB or you had an earth problem. Might be worthwhile having ( if fitted) the split charge relay tested
Take care
Debs and David
Post by Debs and David » Sun Apr 07, 2019 8:43 pm
teenmal wrote: Sun Apr 07, 2019 10:34 am
Take care
Yes strange but Willinton split charge relay is working as normal
Debs & David
