Master Brake Cylinder (2.0l)
Marksbongo
Post by Marksbongo » Mon Mar 11, 2019 3:55 pm
My village mechanic has replaced the break calipers and now believe it needs a Master Break Cylinder replacement. Does anyone know if we can use a diesel engines Master Brake Cylinder from a Bongo the same age? Or does anyone have one close to Salisbury that I can get?
Re: Master Break Cylinder (2.0l)
Post by g8dhe » Mon Mar 11, 2019 4:35 pm
They only show one set of diagrams for all version of the brake system so presuambly they are all identical http://www.lushprojects.com/bongopartsm ... mgno=.html
Marksbongo
Post by Marksbongo » Mon Mar 11, 2019 5:06 pm
That’s great. Thanks. Hopefully the one I’ve found through breaking will work then. VMT.
WestyK
Re: Master Brake Cylinder (2.0l)
Post by WestyK » Tue Mar 12, 2019 10:36 am
I think you will find that ABS and None ABS are different.
One has 3 outlets and the other 2 but, cant remember which way around now.
But as others have said otherwise they seem the same
Post by Northern Bongolow » Wed Mar 13, 2019 1:36 am
The manual gearbox bongo master cylinder is different to the auto box bongo master cylinder as it acts as the master cylinder for the manual clutch too.
Can you not get a service kit if the bore is ok, they are easy to recon, I did mine years ago, but it was a manual gearbox bongo.
Post by teenmal » Wed Mar 13, 2019 11:16 am
Northern Bongolow wrote: Wed Mar 13, 2019 1:36 am The manual gearbox bongo master cylinder is different to the auto box bongo master cylinder as it acts as the master cylinder for the manual clutch too.
I think you might be getting a bit confused here, the manual vehicle Has a Clutch Master Cylinder of its Own. You are probably getting confused by the fact that is uses the Brake Reservoir as a feed, this does not have any effect on the actual Brake Master Cylinder.
TAKE CARE
