Roof wont come down
Pintomo
Roof wont come down
Post by Pintomo » Fri Mar 08, 2019 1:17 pm
Morning All,
Apologies if this has been spoken about before, the roof on my N-reg Bongo is fully up and refusing to come down. When the handbrake is on, the roof open warning light on the dash and the beeper stay off. When I release the handbrake, the roof warning light and beeper come on. Its like the system cant read that the roof is up if the handbrake is on? Has anyone ever seen this before? I've tried to operate the roof with handbrake on and off but getting no joy at all. The other thing is that the roof seems to be sitting higher than it normally does, the tent section is really tight when it normally has a bit of movement in it.
I know there is a way to manually get the roof down but I live up beside Inverness and all the garages I've spoken to up here aren't too keen on taking a look at it so even if I forced the roof shut and tied it off I don't really have anywhere to take it to get fixed!
Any help at all would be appreciated, either on the problem or a Bongo friendly garage up here. I'm having to use my wife's car to get to work as the Bongo is out of the game and her patience is wearing a bit thin!
Thanks, Andrew
Re: Roof wont come down
Post by Bob » Fri Mar 08, 2019 2:20 pm
Obvious one - have you pressed the button up in the roof?
Sorry if I'm talking rot, but it has been missed before. :wink:
Post by g8dhe » Fri Mar 08, 2019 3:03 pm
Try these instructions to the letter!
Make sure that;
The engine is running,
The handbrake is on and the brake light on the dash is lit ??
Press the Un-lock button in the AFT. Beeping starts. (If the roof wasn't fully raised then beeping will start earlier).
Now press Down button.
It will stop half-way for a final visual inspection,
Press Down again.
If not then check the fuses see below,
http://www.g8dhe.net/bwm/default.htm
If the brake light isn't coming on, then check the little switch at the back of the handbrake (remove console) on passenger side they get dusty and dirty.
If the Up/Down button doesn't have any affect then it may be dirty contacts see here https://www.youtube.com/watch?v=tX1SB0xoJOU
Post by Bob » Fri Mar 08, 2019 5:50 pm
Splendid Geoff.
If the switch is faulty the electric window switches are identical, but Geoff's 'Refurb video' is excelent. 8)
Joebri90
Post by Joebri90 » Fri Mar 21, 2025 12:42 pm
Bob wrote: Fri Mar 08, 2019 2:20 pm Obvious one - have you pressed the button up in the roof?
Just registered to say THANKs to this 6 year old post in case you are still around. New Bongo owner here with same issue whilst parked up on the beach, phew it was just the lock switch in roof and it’s back down again now! Many thanks for the info!
Joe
Bongolian
Post by Bongolian » Fri Mar 21, 2025 5:22 pm
For info..
I’ve found simply pressing my ‘cancel’ switch doesn’t always prompt the beeping, however, if I press it while also pressing the ‘up/down’ switch, it more reliably starts the beeping and I’m able to raise/lower as required.
Odd, but might be helpful for others.
Post by g8dhe » Fri Mar 21, 2025 6:53 pm
That sometimes points to the switches needing cleaning, however I've never had to take the cancel-switch in the top of the AFT apart, the Up/Down switch the cab in roof is quite simple https://www.youtube.com/watch?v=tX1SB0xoJOU
Post by Bob » Sat Mar 22, 2025 12:17 am
Joebri90 wrote: Fri Mar 21, 2025 12:42 pm
Joe
Glad the info helped out, welcome aboard. :)
