2.0 petrol - dizzy cap, leads and rotor arm
ognob
Post by ognob » Fri Feb 22, 2019 12:37 am
Recommendations on where to get these,
Anything I need to look out for, don’t want cheaply rubbish which won’t last.
Any bricks and mortar places?
Flanners
Re: 2.0 petrol - dizzy cap, leads and rotor arm
Post by Flanners » Fri Feb 22, 2019 9:21 am
There is a thorough/helpful post by Bonneville from last year
Post by g8dhe » Fri Feb 22, 2019 9:59 am
Post by Ian » Fri Feb 22, 2019 11:04 am
ognob
Post by ognob » Fri Feb 22, 2019 2:45 pm
Thankyou both
Mine has 5 leads, so I assume one is a king lead?
Any ideas on where to get that setup from
Bonneville
Post by Bonneville » Sat Feb 23, 2019 9:00 am
5-pin cap is ADM51427. Lots of alternatives for this style so check yours against the pics.
https://spareto.co.uk/oe/f22018v00a
E-bay for the best price (it's a race to the bottom) 8)
ognob
Post by ognob » Sat Feb 23, 2019 9:11 am
Brilliant, thanks
Any idea on the leads and rotor
This is my first experience of buying non Euro stuff
Bonneville
Post by Bonneville » Sat Feb 23, 2019 9:32 am
Original post is here:
viewtopic.php?f=3&t=75983&hilit=bonneville&start=15
5-pin HT lead set should still be INT76259. 4-pin people throw the king lead away so measure yours to be sure.
Clue on your JDM is to find the other cars that took the same engine and work from there. Here's a 626 set with dimensions:
https://www.autopartssupply.com.au/mazd ... -2.0ltr-fe
You start there then measure, hit the cross reference sites and work it all out that way. There is much copy-paste involved...
ognob
Post by ognob » Tue Feb 26, 2019 1:19 pm
Bonneville wrote: Sat Feb 23, 2019 9:32 am Original post is here:
Thankyou, so is the internal 8mm dimension important, I’m geuessing so. Not done this sort of stuff before.
Now I know how people feel when I try to explain it problems to them!
Bonneville
Post by Bonneville » Wed Feb 27, 2019 9:22 am
No, it's the length. The core size is standard stuff and varies only in quality. Where there's a separate coil, I've seen the 2.0's with coil in 2 different locations. You are looking for a king lead that will reach. The E2000 set will probably suffice but you may have to source a longer one or just re-use your original and replace the 4 main leads (these will work from IT76259). At £11 it's a no brainer for me and those have been on mine for a year with no issues.
On HT, it's more about the length than anything else. You can get kits to make them up yourself which I've found useful on exotics and classics.
ognob
Post by ognob » Sun Apr 07, 2019 5:21 pm
Ok purchased this set, IT76259
King lead is a little short
Anyone got a part / link for the correct king lead
2.0 petrol 2005
Many thanks
