Fuel run back
Razor
Fuel run back
Post by Razor » Tue Feb 19, 2019 5:42 pm
When I have left he car for several hours I won’t start straight away, on investigation it would appear there is no fuel,I then have to crank the engine for several minutes this then flatterns the battery with a jump start it will eventually start.i think the fuel is running back.? Is there a none return valve in the system that would cause this? or am I missing something ?.New fuel filter is on order but don’t know if there is something I am missing.Once started it runs well and when I leave it for an hour or two it starts fine,.😢😢
Re: Fuel run back
Post by Bob » Tue Feb 19, 2019 6:36 pm
Could it be petrol vaporising rather than running back?
Just a thought, and I don't know if you have that, or diesel. :wink:
Razor
Re: Fuel run back
Post by Razor » Tue Feb 19, 2019 8:49 pm
Sorry should have said 1995diesel auto
Re: Fuel run back
Post by g8dhe » Tue Feb 19, 2019 10:47 pm
Quite often on the diesels it can be the seals in the pump that are letting air in and the fuel to run back. Some people overcome the problem for a while by putting a non-return valve in the fuel line, others just replace the seals and cure the problem.
Re: Fuel run back
Post by Northern Bongolow » Tue Feb 19, 2019 11:30 pm
See if it's better with the fuel cap loose or off.
The following is usually after running for a while then stopped but it
may be the fuel cap needs washing out, or the one way valve on the fuel tank breather blocked. These can cause a vac in the tank so it sucks back towards the tank when stopped previously.
Re: Fuel run back
Post by mikeonb4c » Wed Feb 20, 2019 12:06 am
Razor wrote: Tue Feb 19, 2019 5:42 pm When I have left he car for several hours I won’t start straight away, on investigation it would appear there is no fuel,I then have to crank the engine for several minutes this then flatterns the battery with a jump start it will eventually start.i think the fuel is running back.? Is there a none return valve in the system that would cause this? or am I missing something ?.New fuel filter is on order but don’t know if there is something I am missing.Once started it runs well and when I leave it for an hour or two it starts fine,.😢😢
As Geoff has said, fuel pumps seals could be the cause. I seem to recall an owner once saying theirs was fine if parked facing down a hill but wouldnt start after being left parked facing uphill. That could maybe be used as a test for cause. Also check Ady's filler cap suggestion. Good luck and keep us posted.
Russell Jupp
Re: Fuel run back
Post by Russell Jupp » Sat Feb 23, 2019 10:10 pm
Does it have 'leak back pipes' from each injector? Little rubber pipes that return unused fuel to the pump.
My zafira had a split in one of these. It would only start if left facing downhill.
The key to life: Fast bikes, fast cars, fast women. And a Bongo.
Re: Fuel run back
Post by g8dhe » Sat Feb 23, 2019 11:42 pm
Yes not sure rubber looks more like a steel tube! 13-6702
http://www.lushprojects.com/bongopartsm ... no=.html#8
Re: Fuel run back
Post by teenmal » Sat Feb 23, 2019 11:53 pm
Russell Jupp wrote: Sat Feb 23, 2019 10:10 pm Does it have 'leak back pipes' from each injector? Little rubber pipes that return unused fuel to the pump.
This is the hose from the l/o rail to the pump.
https://www.ebay.co.uk/itm/GENUINE-MAZD ... 2611799332
