2.5td rattle from engine, stops when turning steering.
Russell Jupp
- Bongonaut
Morning all,
Among the many little jobs to sort, I've noticed a rattle from the motor.
Only apparent after about 5 mins from starting, but it stops as soon as I turn the steering wheel.
Turn it left or right slightly, and it comes and goes in time with the steering.
Really difficult to determine exactly where it's coming from.
Any ideas?
Tia
Russ
Any ideas?
Tia
Russ
The key to life: Fast bikes, fast cars, fast women. And a Bongo.
- haydn callow
Re: 2.5td rattle from engine, stops when turning steering.
Check the level of your power steering fluid and go from there....report back
Russell Jupp
- Bongonaut
Hi, thanks for your reply.
Fluid level is fine, although the rack has a leak from the top seal, which I’ve just ordered.
It’s deffo a mechanical rattle , just difficult to establish where exactly it originates.
Russ
Russ
- haydn callow
Must be something to do with the steering rack.
Russell Jupp
- Bongonaut
Ok, so I've just driven my other, beloved Bongo, and thought....I wonder if this one makes the same noise.....
It would appear that it does.
Anyone else care to have a listen to their own please?
I did record the sound on my iPhone, but I'm jot yet clear on how to upload it.
Tia
Russ
It is most noticeable at idle and slightly above.
Tia
Russ
TheLongRoad
Maybe worth checking the belt and pulleys that drive the power steering pump. Perhaps they are worn and the increased load when steering ‘hides’ the rattle?
2002 Friendee 2.0 ltr Petrol.
The WLTD PSP is gear driven no belt.Depending on the noise it could be various things /low pressure/worn blades / plunger spring/gunge etc.
Russell Jupp
- Bongonaut
Hi, yep took a look today. Clearly driven internally, directly from the crank?
Motor is sweet, other than this annoying little rattle.
When you mention pressure, do you mean engine oil pressure?
Turning the steering increases load on engine and may drop its rpm slightly. This might be all that is needed to stop - for example- noises like a squeaky fanbelt. I had a rattle/squeak on cold mornings especially on low tickover only for the first 5-10 mins of running and it was cured finally by adjusting the fanbelt. I'm not saying thats your problem but its possible an rpm change could be linked, and my fanbelt noise sounded more like a bearing than a belt
Russell Jupp
- Bongonaut
Thanks for that, worth a look....
No the PSP pressure.Russell Jupp wrote: Mon Dec 10, 2018 7:00 pm Hi, yep took a look today. Clearly driven internally, directly from the crank?
