I am installing a solar panel and have the controller wired in with the cables coming into the roof area behind the tail gate. I'd like to know the best way to get the wire routed. It has to go through the roof, up behind the canvas then through the actual pop top. When the roof closes the entry point in the van would be covered by the pop top.
I was wondering if a cable box and gland would be best on the pop top, then another plain gland into the van. The cable between the two would partially curl up under the roof when closed. It's a single cable H07RN-F 10 mm diameter
Any one done this type of install and is there a clever way of doing it that I'm missing?
cheers!
