Rear near side window.
smith335
Post by smith335 » Mon Nov 05, 2018 8:03 pm
hope some one can help.
I have a 2004 aero city runner , and all the rear windows open apart from the very rear near side one.
the opener on the very rear near side is different to all the others, as in the bit you would pull to open the window is a different shape and slightly behind the trim.
is this normal that the window does not open ? maybe to stop the sliding door hitting a open window ?
or has the trim been moved and not put back correctly.
just thought i would would ask, before i start removing trim....
thanks in advance
Az
2004, 2.0L Aero City Runner
Re: Rear near side window.
Post by Bob » Mon Nov 05, 2018 8:19 pm
You're right.
This window does not open so that the sliding door doesn't make contact, they're all like this. :wink:
smith335
Post by smith335 » Mon Nov 05, 2018 8:52 pm
Many thanks,
thought it might be something to do with the sliding door.
cheers
