Diagnostic socket help
LogicUK
Post by LogicUK » Fri Sep 21, 2018 1:59 pm
Can someone help me on this. I have a coil light flashing on a 2.5 diesel auto. Can my find anything on getting flash codes with the plug I have. See Flickr link. Thanks
https://flic.kr/p/28wM2qW
Re: Diagnostic socket help
Post by g8dhe » Fri Sep 21, 2018 2:09 pm
Here is a link to the original codes and methods, but later versions since 95-97 have variations all on the same theme;
http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
Later models don't always need the light added as they flash the code on the glowplug light itself, even later versions use a 4-digit code and the mast few years also had genuie OBDII sockets down by the drivers LEFT knee under the dashboard.
LogicUK
Post by LogicUK » Fri Sep 21, 2018 5:44 pm
Thanks for the reply. I did see that site but I don't seem to have the same layout or an engine one.
Post by g8dhe » Fri Sep 21, 2018 8:11 pm
Can you elaborate on that ? The box is mounted upside down so you need to invert the diagrams, maybe that's the problem ?
