Wheel nuts
Eratosthenes
Wheel nuts
I have a v6 year 2000 fitted with alloy wheels.
If I am to get a set of steel wheels for the winter, will the existing wheel nuts be suitable.
If not, any pointers where to get some from.
Re: Wheel nuts
They are most likely different, not sure if Mazda original alloys use the same nuts, and I guess any of the breakers will have them.
Bongo Spares...
Bongo Spares...
Re: Wheel nuts
No there not suitable the chamfer angle is different between steel and alloys.
Eratosthenes
Re: Wheel nuts
Thanks both for the replies.
Eratosthenes
Re: Wheel nuts
That's got me thinking now. Although I changed my skinny spare for a steel, I never considered that the alloy nuts wouldn't fit!
Re: Wheel nuts
Hmmmm - I've been in the same predicament for years. I suspect (though perhaps techies can confirm) that for limited miles and where common sense is used it'd be ok to use the steel spare with the alloy's wheel nuts.Eratosthenes wrote: Wed Sep 19, 2018 12:03 pm That's got me thinking now. Although I changed my skinny spare for a steel, I never considered that the alloy nuts wouldn't fit!
Re: Wheel nuts
Check the profile of the nuts,I would be surprised (if you have Mazda alloys) that the nuts were different profile for steel wheels.
Eratosthenes
Re: Wheel nuts
Thanks for the post.teenmal wrote: Thu Sep 20, 2018 9:33 amEratosthenes wrote: Wed Sep 19, 2018 12:03 pm That's got me thinking now. Although I changed my skinny spare for a steel, I never considered that the alloy nuts wouldn't fit!
The alloys on my Bongo were on when imported. They have a Mazda logo on the centre cap and I have seen them on other Bongos and have assumed they were original. When the weather calms down a bit, I will remove a nut and match it to the steel spare ( a Mazda one) and to the steels I should receive next week. I will come back with my findings.
Re: Wheel nuts
That makes a great deal of sense. The wheelnut thing has floated about for years but surely if Mazda have offered Bongos with alloys and a steel skinny spare then the same wheelnuts should work on all wheels at least in those cases.teenmal wrote: Thu Sep 20, 2018 9:33 amEratosthenes wrote: Wed Sep 19, 2018 12:03 pm That's got me thinking now. Although I changed my skinny spare for a steel, I never considered that the alloy nuts wouldn't fit!
Re: Wheel nuts
Not sure about the Bongo as i dont have alloys but some manufacturers (Mercedes & Renalt are the 2 that spring to mind first) use different bolts for some of there spare wheels. Many Merc models use shorter bolts for the spare & many Renults use fixed bolts instead of ones with floating washers for the spare. I would have thought it to be very unusual to use nuts with different taper angles though.
95 2.5d 4WD AFT
Eratosthenes
Re: Wheel nuts
Just an update, as Teenmal thought, the wheel nuts for the Mazda Alloys do fit the steels fine. Got the wheels balanced and swapped today.teenmal wrote: Thu Sep 20, 2018 9:33 amEratosthenes wrote: Wed Sep 19, 2018 12:03 pm That's got me thinking now. Although I changed my skinny spare for a steel, I never considered that the alloy nuts wouldn't fit!
Re: Wheel nuts
Useful update, thanks.
Re: Wheel nuts
Interesting, others in the past have found they don't fit, maybe they weren't Mazda wheels.
Eratosthenes
Re: Wheel nuts
Just out of interest, the hole for the nut on the skinny spare was identical to the steels.
Thanks for the comments and input.
