Rear aircon lights up but doesn't work
Edinburgh Phil
Post by Edinburgh Phil » Fri Sep 14, 2018 11:05 am
Hello all,
I've searched this excellent site but can't find an answer to this question...
Our front aircon works ok although doesn't run very cold (presumably needs re-gassing). The problem is the rear aircon.
The rear controls have been moved to the back of the hob/sink conversion unit (facing rear seats). They light up when turned on but no air comes out, either through top vents or vents under the sink/hob. We've tried switching on 'rear' on the front controls, and also swapping between high and low rear preferences (on front controls), but no joy.
Any advice for a Bongo novice greatly appreciated!
Re: Rear aircon lights up but doesn't work
Post by g8dhe » Fri Sep 14, 2018 1:45 pm
You've found the need to switch on from the front so that is good, but if its not functioning then possibly a cable might have been pulled out or similar. Fuses and wiring details available here http://www.g8dhe.net/bwm
