No fuel
mfc1476
No fuel
Post by mfc1476 » Tue Sep 04, 2018 6:49 pm
I have just replaced head gasket along with a load of other parts .Timing belt, water pump ,rad, hoses, battery the list goes on.
But now it won't start it's a t 98 2.5 TD I am not getting fuel to the injectors I have removed a pipe cranked it and nothing.
Any ideas???
mfc1476
Re: No fuel
Post by mfc1476 » Tue Sep 04, 2018 6:59 pm
Is there a way to bleed fuel system as it could be air locked
Re: No fuel
Post by Northern Bongolow » Wed Sep 05, 2018 2:47 am
Remove the pipe to the filter from the tank,pull fuel up using a pump or suck hard, remove filter pipe to fuel pump, repeat,this fills the filter with fuel. The older models sometimes had a primer on top of the filter housing, turn to unlock then pump till the filter is full. In the centre of the injector pipes 0n the high pressure head is a triangular nut loosen this and crank the engine till you see fuel, cover with a rag so it doesn't squirt everywhere if it fires. If not crack the injector pipes at the injector ends and cover again, it can make a mess of the cabin if it fires, nip em up as you see fuel at each it should then go.
Make sure you have good fuel level in as the gauges are not the most accurate, jacking up the rear may help with the above as the tanks are long and thin but not over deep.
mfc1476
Re: No fuel
Post by mfc1476 » Wed Sep 05, 2018 9:50 am
Thanks for the info I will try today and let you know how o get on.
Re: No fuel
Post by teenmal » Wed Sep 05, 2018 10:12 am
The easiest way is to remove the banjo bolt and feed pipe from the top of the pump, fill the pump with fuel ,start the engine , keep the pump full ,switch off then reconnect everything .
Good Luck.
Re: No fuel
Post by mikeonb4c » Wed Sep 05, 2018 11:23 am
teenmal wrote: Wed Sep 05, 2018 10:12 am The easiest way is to remove the banjo bolt and feed pipe from the top of the pump, fill the pump with fuel ,start the engine , keep the pump full ,switch off then reconnect everything .
Good Luck.
Sounds simple and sensible to me =D>
