Fridge - split relay
Dobbo101
Post by Dobbo101 » Thu Aug 30, 2018 11:30 am
Hi Folks. Trying to work out why our fridge has stopped working. Both batteries have over 12v. I’ve tested the relay below and it shows power through the connections on the left but nothing running out of the right one to the leisure battery. Will this only go live when the power in the LB drops or have we got a fault? If so, might this effect the fridge. Any help greatly appreciated. Thanks.
Re: Fridge - split relay
Post by g8dhe » Thu Aug 30, 2018 11:44 am
Really need good clear images to help on this, often of course is the fact that the fridges have a low-voltage cut-off which means they will fail to work when the voltage at the fridge itself is below the required level.
