Our newly acquired machine has one of these fob type immobilisers. But only one fob! Naturally I'm petrified of losing it.
I gather it's possible to get new ones but by programming them in tge old fob is rendered inoperative.
As anyone done this? I don't want to try it and find the van completely immobilised!!
Sterling Excel immobiliser
brianjeff50
- Apprentice Bongonaut
Re: Sterling Excel immobiliser
I don't know this particular make at all but all of the systems I have dealt with in the past you reprogram all the fobs you have at the same time when adding a new one, any not done when adding a new one will be kicked out & wont work in case it has been lost.
How you program in a new fob varies between systems, some require a security code & some require access to the control box, which if fitted properly should be well hidden.
95 2.5d 4WD AFT
