Ignition barrel
BongoTraveller
Ignition barrel
Post by BongoTraveller » Fri Aug 10, 2018 3:55 pm
Any help appreciated on this!
The metal tab on the end of my ignition barrell has sheared off. So I ordered a new (used) barrel. But the replacement part isnt the same. My existing barrel has three fixing points built into the housing, whereas the replacement one doesnt have these, so cant be fitted. :?
Do you know how I can get the right replacement part?
Thanks!
nth
Re: Ignition barrel
Post by nth » Fri Aug 10, 2018 4:11 pm
Do you have pics ?
95 2.5d 4WD AFT
BongoTraveller
Re: Ignition barrel
Post by BongoTraveller » Fri Aug 10, 2018 4:36 pm
Just to follow up my post (hope that's not too bad form), it looks as though I mistakenly ordered the non-airbag model part. The airbag version (which I need) has a long bracket attachment and a couple of other fixing points.....
Re: Ignition barrel
Post by Bob » Sat Aug 11, 2018 2:19 pm
Easy mistake.
Let's hope you're sorted soon. 8)
