I'd be looking for something spilled or cooking residue before thinking it's vehicle related.
Bear in mind the source could be some distance from the hole, just running to that as the only/lowest exit point.
We're at the Anchor, High Offley, at the end of August if you want me to take a look. 27th to 3 Sept.
Also, scratching my head, I wonder if someone has used some mastic/tar type substance/adhesive during the conversion and it's melting with the current heat?
