Anyone got any advice for sourcing replacement front brake hoses. The garage can fabricate the metal ones, it's the rubber ones that are elusive. Getting desperate now as trip fast approaching. Any other Mazda models work or anywhere that can make them up?
Any help very gratefully appreciated.
Graeme
Rubber brake hoses
Re: Rubber brake hoses
Seem to be plenty on ebay. You can use this to get the Blueprint part numbers and compare to your sizes:
https://partsfinder.bilsteingroup.com/e ... +bongo&f=4
Dimensions are given for some of them so you can compare with yours.
Autojapspares do next day delivery....Just make sure that they are not sided as the rears.
https://www.ebay.co.uk/itm/MAZDA-BONGO- ... Swi4laeu8p
Thanks for the ideas. Unfortunately I am abroad and the garage needs them asap.
Can anyone possibly pass on the details that I could use to get them made up or check the pre fabricated ones.
They are for a 95 2.5 TD 2WD
Will try the suggested sites too. Thank you.
TIA
Graeme
TIA
Graeme
One of those is also listed for a Honda Prelude which may help your garage.
Don't know how close you are to civilisation but, if you can stand the cost, braided lines can be made to any size or fitting. There needs to be a 'speed shop' nearby like a Demon Tweeks equivalent:
https://www.demon-tweeks.com/uk/motorsp ... -adaptors/
Just an update for anyone looking in the future. Mazda bongo dot com have them. £48 / side
