V6 pressure switch ATF
xt600
Post by xt600 » Sun Jul 15, 2018 6:08 pm
Does anyone know where I can get a new pressure switch, mine has started to leak fluid :-)
Re: V6 pressure switch ATF
Post by teenmal » Mon Jul 16, 2018 2:09 pm
Is the item on the off side of the box.?
xt600
Post by xt600 » Mon Jul 16, 2018 3:02 pm
Yes, it's at the end close to the prop shaft. Assume it's a pressure switch, and it's leaking a little fluid...
Post by teenmal » Mon Jul 16, 2018 8:36 pm
It sounds like the speed sensor, it should be held in by a set screw/bolt , probably needs an O ring, or check it for play.
xt600
Post by xt600 » Mon Jul 16, 2018 9:23 pm
It's leaking out around the wires so I think the leak must be internal. Are they easy enough to get hold of and replace?
xt600
Post by xt600 » Fri Jul 27, 2018 5:15 pm
xt600 wrote: Mon Jul 16, 2018 9:23 pm It's leaking out around the wires so I think the leak must be internal. Are they easy enough to get hold of and replace?
Take that as a 'no' then!
Post by Bob » Fri Jul 27, 2018 5:53 pm
Possibly a 'Don't know'. :wink:
Post by g8dhe » Fri Jul 27, 2018 6:02 pm
Is it that speed sensor your talking about? There isn't any form of pressure switch on the auto transmission .
Have you cleaned it up and has the oil returned ?
Is it part 21-5H2 lower right corner ? If so that is the speed sensor.
Post by teenmal » Fri Jul 27, 2018 7:12 pm
If the item is on the o/s of the box its the speed sensor, 17-400 on the drawing.
xt600
Post by xt600 » Mon Jul 30, 2018 2:03 pm
Yes, thanks, appears to be the speed sensor. I presume the petrol and diesel models are the same. Anyone know where I can get a new one, or do I need to visit the local scrappy for a second hand one?
Post by teenmal » Mon Jul 30, 2018 3:16 pm
If it is the speed sensor drive .. the part number BV8217400..your local Mazda dealer is your best bet. It is not the same as the 2000/2.5td .
You could also try gear box repair centre.
xt600
Post by xt600 » Tue Jul 31, 2018 12:26 pm
Thanks for your replies, due to the rip off prices of new parts (and some used!) I think I'll wait until one becomes available second hand :-)
Post by teenmal » Tue Jul 31, 2018 3:04 pm
Just remember to have it fixed for the next MOTT, its a fail otherwise .
xt600
Post by xt600 » Wed Aug 01, 2018 9:55 pm
teenmal wrote: Tue Jul 31, 2018 3:04 pm Just remember to have it fixed for the next MOTT, its a fail otherwise .
It's only seeping, not dripping out so won't be a problem for the mot :-)
