Window switches
Posted: Wed Jun 20, 2018 3:46 pm
by TheLongRoad
How do you separte the trim from the switch on the electric window control? See picture here, can it be done with the door card in place?
Re: Window switches
Posted: Wed Jun 20, 2018 4:58 pm
You can remove the switch entirely without removing the door card. Push the switch forwards towards the door hinges, then lift the end up using a flat blade (sprung clip), then slide the door switch out away from the hinges - be aware plastic clip at hinge end will snap if you lift at any steep angle! Once out then the cable can be unplugged and the switch worked on - again be aware quite a lot of electronics and relay on the PCB which is difficult to remove as the switches and plug are soldered in.
Re: Window switches
Posted: Wed Jun 20, 2018 7:33 pm
by TheLongRoad
Cheers g8dhe. Worked a treat and just the info I needed.
Re: Window switches
Posted: Wed Jun 20, 2018 9:46 pm
by Northern Bongolow
