Window switches
TheLongRoad
Window switches
Post by TheLongRoad » Wed Jun 20, 2018 3:46 pm
How do you separte the trim from the switch on the electric window control? See picture here, can it be done with the door card in place?
2002 Friendee 2.0 ltr Petrol.
Re: Window switches
Post by g8dhe » Wed Jun 20, 2018 4:58 pm
You can remove the switch entirely without removing the door card. Push the switch forwards towards the door hinges, then lift the end up using a flat blade (sprung clip), then slide the door switch out away from the hinges - be aware plastic clip at hinge end will snap if you lift at any steep angle! Once out then the cable can be unplugged and the switch worked on - again be aware quite a lot of electronics and relay on the PCB which is difficult to remove as the switches and plug are soldered in.
TheLongRoad
Re: Window switches
Post by TheLongRoad » Wed Jun 20, 2018 7:33 pm
Cheers g8dhe. Worked a treat and just the info I needed.
Re: Window switches
Post by Northern Bongolow » Wed Jun 20, 2018 9:46 pm
then its time to play - - - hunt the ball bearing. :lol: :lol: :lol: :lol: :lol: :lol: :roll:
