thickness of figure of 8 awning
Moderator: Muzorewa
fordmill
Post by fordmill » Wed May 30, 2018 11:12 am
Hi Folks,
Does anybody know what the thickness of the figure of 8 kit I need for a bongo?.
Seen them on ebay but not sure of right thickness to buy, Can anybody shed some light please.
Regards
Re: thickness of figure of 8 awning
Post by g8dhe » Wed May 30, 2018 11:16 am
There are two sizes 6mm and 8mm, you need to use the size that fits your awning and the gutter of the van;
fordmill
Post by fordmill » Wed May 30, 2018 11:20 am
Thanks for your reply, So I don't need the double edged beaded tape or awning channel ?
tootsmcfruits
Post by tootsmcfruits » Wed May 30, 2018 11:45 am
fordmill wrote: Wed May 30, 2018 11:20 am Thanks for your reply, So I don't need the double edged beaded tape or awning channel ?
You need it if you want to be able to drive away from your awning.
viewtopic.php?f=1&t=74583&hilit=awning+strip
#sayhellotomylittlefriendee
fordmill
Post by fordmill » Wed May 30, 2018 5:27 pm
Just a bit confused, ive bought a drive away awning, so will I still need the drive away kit ?
Flanners
Post by Flanners » Wed May 30, 2018 5:44 pm
WIth Outdoor Revoulution you usually need to buy the fitting kit which is shown in the pictures above. Without causing you more concern I am not 100% but are the XL awnings not for van's that are 2.4m high or more, the standard awning would fit the Bongo, I would check this out with Outdoor Revolution before fitting and using it, hopefully I am incorrect.
Markas
Post by Markas » Wed May 30, 2018 7:57 pm
Flanners wrote: Wed May 30, 2018 5:44 pm WIth Outdoor Revoulution you usually need to buy the fitting kit which is shown in the pictures above. Without causing you more concern I am not 100% but are the XL awnings not for van's that are 2.4m high or more, the standard awning would fit the Bongo, I would check this out with Outdoor Revolution before fitting and using it, hopefully I am incorrect.
Hmmm, I fear you may well be correct Flanners. One listing for the Movelite Cayman XL states the awning rail height as in the range 240 -290 cm :(
Mark
