just finished the sump seal on engine today, bloody chuffed to bits and tomorrow will commence all belts water pump thermostat and ac pulley with coolant flush,
coolant alarm installed(thanks bob 25 quid well spent) and when tank is empty will get drillin' to finish it off
also the write ups were very useful in members area (must have membership for any bongo lover)
so to cap off
full fluid change diff oil (which came out like glue) dont think thats ever been changed, gearbox oil and filter clean (mind dont over tighten screws)
and when ma pela pump arrives ill do the steering fluid (which doesn't look too healthy) got rust converter cos the rear arches have slight surface corrosion and will repaint them too.
all in all about 650-700 quid well spent to keep the weebeast on the road (reg: W331EAW) and running perfect (if theres such a thing)
hopefully i can get a pitch at the bongo bash in june and thank you all personally(if your there)
NOW time for a nice big glass o glenfiddich select cask mmmmmmmmm your right BOB alcohol wont solve my problems but it makes you feel damn good after many hours on a bongo
CHEERS TO ALL
