auto box sump torque
knpenny
Post by knpenny » Sun Apr 01, 2018 1:07 pm
hi does anyone know torque settings for the autobox sump bolts?
thanks in advance
Bongology, the study of all things bong. The bongologist. :shock:
Alacrity
Re: auto box sump torque
Post by Alacrity » Tue Apr 03, 2018 5:05 pm
6nm
knpenny
Post by knpenny » Fri Apr 06, 2018 10:00 pm
:oops:
knpenny
Post by knpenny » Fri Apr 06, 2018 10:09 pm
what effects if any would torque settings that are too high have on the auto box sump screws. :oops:
thanks in advance
Post by Bob » Sat Apr 07, 2018 10:19 am
I would guess the sump may warp so not seal properly. :(
knpenny
Post by knpenny » Sat Apr 07, 2018 4:33 pm
guess i'll be doing it again :oops: at least the coolant alarm works well. merde
thanks for the reply
Billybongo123
Post by Billybongo123 » Sat Apr 07, 2018 6:46 pm
As long as your haven't gone mad it will be okay. I'd certainly be leaving it first, and monitoring leaks. You might be okay.
You can damage the threads in the alloy casting before you warp these sumps anyway, tbh. They are pretty good. I used to work with ZF boxes a lot, the sumps were similar, and are pretty resilient, based on my experience. Much better than the plastic ones anyway. 👍😂
We love our rusty Bongo "Billy", despite his many faults!
knpenny
Post by knpenny » Sun Apr 08, 2018 8:05 pm
Be honest i have had it out every day for at least half an hour and been checking it like crazy since i done it, all seems well so far and i did use some tough as hell silicone sealant along with the gasket just for good measure, so will be continuing to monitor it for now.
will have it in the workshop to change all the belts and ac pulley on tuesday and at the same time i am going to sort the sump on the engine as someones previous attemp to seal it with what looks like low grade white silicone doesn't seem to be holding well [-X , its leaking at the back end of the sump, so i think i might just redo it the when i sort the others out.
any idea of torque settings for the oil sump? [-o< and thanks for the reassurance, i swear by the time ive finished i think i'll be bored as hell cos there wont be much if anything to do after that. :lol:
Billybongo123
Post by Billybongo123 » Sun Apr 08, 2018 8:53 pm
I'fv they are m6 it will be about the same, I just do hand tight with 1/4 drive ratchet but my hands are calibrated 😂👍
knpenny
Post by knpenny » Sun Apr 08, 2018 9:35 pm
:lol:
knpenny
Post by knpenny » Mon Apr 09, 2018 8:05 pm
good news billy, the gearbox is not leaking and i did the engine sump gasket todat. good times had. cheers for advice =D>
Billybongo123
Post by Billybongo123 » Mon Apr 09, 2018 9:02 pm
Good news man, good effort. Marc
