Gear box
Wayne
Gear box
Post by Wayne » Sat Mar 17, 2018 3:48 am
Hi I recently bought a Mazda bongo and have discovered it won't go into top gear (3k revs) at 60. That would probably be why he he was reluctant about a good test drive I didn't get it up to that speed in a residential area, maybe I should of persisted in going on a dual carriageway. What's done is done anyway It drives really well though no lights on etc. What could this be.?
Also I've fitted a new split charger leisure battery 120ah wiring bits and bobs and discover it only powers 2lights and the fridge the mains runs the cig lighters etc can I upgrade this ? I'm new to owning a bongo or any camper any advice would be great.
Billybongo123
Re: Gear box
Post by Billybongo123 » Sat Mar 17, 2018 7:48 am
First thing that's easy is check oil level etc and its condition. Is it petrol or diesel?
We love our rusty Bongo "Billy", despite his many faults!
Alacrity
Re: Gear box
Post by Alacrity » Mon Mar 19, 2018 2:56 pm
Waste of time checking oil level for THIS fault, oil quality maybe (is it black & smells burnt?), as the transmission is electronically controlled so you need to be looking at fault codes etc. I assume to HOLD light comes on & off with the button & it isn't on all the time? If it is it will never shift to top. Poss TPS issue or speed sensor assuming all is well in the trans.
Re: Gear box
Post by teenmal » Mon Mar 19, 2018 4:20 pm
This might give you an idea of the rpm to gear position/mph.
Gear Ratios
(mph/2000rpm) for each
gear.
1st – 11.2MPH
2nd – 20.4MPH
3rd – 32.0MPH
4th – 50.3MPH
+/- 8%
Take Care
LJColeman
Re: Gear box
Post by LJColeman » Mon Sep 02, 2019 9:12 pm
It seems I also have this issue on my recently purchased bongo.
On occasions it will select 4th but then a few seconds later it will jump back to 3rd and then may not select 4th again for the rest of the journey.
Any ideas?
Flanners
Re: Gear box
Post by Flanners » Tue Sep 03, 2019 8:05 am
as per Alacrity's post: TPS issue etc
