Bongo v6 rattle and clatter
Billybongo123
Post by Billybongo123 » Thu Mar 08, 2018 8:50 pm
Hello, bought a Bongo couple weeks ago. After only 100km it has started to make a horrific rattle that sounds like either engine or gearbox. Is there anything common that fails on these? It got me home but sounded horrible. Like rod knock but intermittent at times.
We love our rusty Bongo "Billy", despite his many faults!
knpenny
Re: Bongo v6 rattle and clatter
Post by knpenny » Thu Mar 08, 2018 9:49 pm
Is the rattle/knock in time with engine speed or does it increase the faster you go? or does it increase then decrease slightly through gear changes and increase again.
Do you hear it at a stand still?
Bongology, the study of all things bong. The bongologist. :shock:
Billybongo123
Post by Billybongo123 » Thu Mar 08, 2018 9:57 pm
I can feel the knock with my feet when stood in the rear, I think it's in bell housing of the auto box? Not the engine?
Billybongo123
Post by Billybongo123 » Thu Mar 08, 2018 9:58 pm
Even idling in neutral it's there
knpenny
Post by knpenny » Thu Mar 08, 2018 10:06 pm
alacrity is your guy for gearbox issues, however if you're sitting at idle and knocking is occuring i am not sure it is the box.
Have you checked all your oil levels?
knpenny
Post by knpenny » Thu Mar 08, 2018 10:14 pm
You'll find Alacrity in gearbox fault diagnosis post 11 posts under this one. hope that helps locate him.
I am quite new to the forum but top tip, pay the 13 quid for the members area and you can get a wealth of invaluable info at your fingertips.
one thing i have found is that everyone tries thier best to help or guide you to the right place.
Also if you need specialist parts being a member generally gets you a 10% discount :D
I already used mazdabongo.com for a few parts i couldnt find elsewhere :wink:
Billybongo123
Post by Billybongo123 » Thu Mar 08, 2018 11:40 pm
knpenny wrote: Thu Mar 08, 2018 10:06 pm alacrity is your guy for gearbox issues, however if you're sitting at idle and knocking is occuring i am not sure it is the box.
It's deffo coming from the torque converter or auto box is say, rather than engine.
Post by mikeonb4c » Fri Mar 09, 2018 12:10 am
Billybongo123 wrote: Thu Mar 08, 2018 8:50 pm Hello, bought a Bongo couple weeks ago. After only 100km it has started to make a horrific rattle that sounds like either engine or gearbox. Is there anything common that fails on these? It got me home but sounded horrible. Like rod knock but intermittent at times.
The Bongo autobox is generally a sturdy beast. How old is the Bongo and whats the mileage. Have you checked the transmission fliud for condition and level?
Alacrity is based near Eastbourne, in case that helps.
Seems odd it went within 100kms of purchase :-k
Billybongo123
Post by Billybongo123 » Fri Mar 09, 2018 12:39 am
mikeonb4c wrote: Fri Mar 09, 2018 12:10 am
It drives etc, it's just this clatter. I'll check a few more things tomorrow, I wonder if there's an easy way to check the flex plate mount bolts etc. First off it sounded like a bolt fell out.
Post by teenmal » Fri Mar 09, 2018 7:30 pm
Possibly the transmission mounts or engine mounts, worth a check also the exhaust system. Its very hard without hearing it first hand.
Take Care
Post by Northern Bongolow » Sat Mar 10, 2018 3:13 am
check the front crank shaft pulley, or is the starter motor sticking in drive, rattling on the fly wheel.
Billybongo123
Post by Billybongo123 » Sat Mar 10, 2018 9:06 am
Hey guys, I think it might be the engine bottom end, in going to drain I'll and look for bearing material today. I'm gutted.
When I listen with engine covers up, sounds like engine is knocking. I'll keep you posted.
Billybongo123
Post by Billybongo123 » Sat Mar 10, 2018 7:46 pm
It's the bottom end, Mr Motorhome UK has fiddled me. Engines bolloxed. Fed up, all we wanted to do was take little one camping. I now have an 8k paperweight. 😭👎
I'll try and get some money out of him, but not feeling very hopeful, I'll be honest. I'll keep you all posted. Marc
Flanners
Post by Flanners » Sat Mar 10, 2018 7:54 pm
Nightmare situation, this will help deal with Mr Motorhome UK, one week in, you have a great case read through this:
http://www.mils.co.uk/images/How_the_Ne ... _Trade.pdf
Just out of interest what mileage has it done, year and year of import?
Billybongo123
Post by Billybongo123 » Sat Mar 10, 2018 9:53 pm
Flanners wrote: Sat Mar 10, 2018 7:54 pm Nightmare situation, this will help deal with Mr Motorhome UK, one week in, you have a great case read through this:
Cheers for that buddy, even though I'm not a motor trader etc he wrote trade sale on the receipt and no warranty given. He didn't give the trade section of v5 though, we did like normal. Not sure if I'm covered or not, but I'm still gutted. Odd issues are normal in old cars but didn't expect an engine failure.
It's a T reg, imported 2010 I think? Converted by well house leisure. It's a lovely conversion with webasto and the lot. Just some of the usual rust to sort, and now this.
Not what I had in mind.
