				Roof Mount
				Posted: Wed Mar 07, 2018 8:14 am
				by mike_glos
				Hi All,
Would probably by useful if there was a brief fact sheet on this as it appears I am not the only person struggling to get correct M8 bolt.
It is suggested on here that a 1.5 or 15 mm thread is required.
Standard thread size for M8 I believe is 0.7 mm.
If it is 1.5 supplier links would also be appreciated.
Thanks,
Mike
				Re: Roof Mount
				Posted: Wed Mar 07, 2018 10:21 am
				by Bob
				Re: Roof Mount
				Posted: Wed Mar 07, 2018 10:41 am
				If its the threaded inserts in the roof, be sure to use a corrosion proof / stainless steel bolt. If they bind at all you can have a fun time trying to get them out as the inserts may lose their grip on the roof structure (from old half remembered memory!)
				Re: Roof Mount
				Posted: Wed Mar 07, 2018 11:37 am
				by teenmal
				mike_glos wrote: Wed Mar 07, 2018 8:14 am
Hi All,
Thanks,
Mike
https://www.ebay.co.uk/itm/A-Pack-20-A4 ... V2vaVeBJMQ
				Re: Roof Mount
				Posted: Wed Mar 07, 2018 1:14 pm
				by mike_glos
				Thanks All. much appreciated
				Re: Roof Mount
				Posted: Fri Mar 09, 2018 11:11 pm
				by Ahead
				I got a bag of M8 with hex key head from Screwfix, fitted perfectly. Got loads over if you’re struggling pm me and I’ll see if I can find them..
				Re: Roof Mount
				Posted: Sat Mar 10, 2018 10:15 am
				by Bob
				Useful info, thanks.
				Re: Roof Mount
				Posted: Sat Mar 10, 2018 10:57 pm
				by mike_glos
				Yes to be fair the set of M8s I had already got from ebay did the job:
https://www.ebay.co.uk/itm/M8-8mm%C3%98 ... 2749.l2649
