Roof Mount
mike_glos
Roof Mount
Post by mike_glos » Wed Mar 07, 2018 8:14 am
Hi All,
Would probably by useful if there was a brief fact sheet on this as it appears I am not the only person struggling to get correct M8 bolt.
It is suggested on here that a 1.5 or 15 mm thread is required.
Standard thread size for M8 I believe is 0.7 mm.
If it is 1.5 supplier links would also be appreciated.
Thanks,
Mike
Re: Roof Mount
Post by Bob » Wed Mar 07, 2018 10:21 am
Try T E Stone, Old Market, Bristol.
https://www.yell.com/biz/te-stone-ltd-bristol-54600/
Re: Roof Mount
Post by mikeonb4c » Wed Mar 07, 2018 10:41 am
If its the threaded inserts in the roof, be sure to use a corrosion proof / stainless steel bolt. If they bind at all you can have a fun time trying to get them out as the inserts may lose their grip on the roof structure (from old half remembered memory!)
Re: Roof Mount
Post by teenmal » Wed Mar 07, 2018 11:37 am
mike_glos wrote: Wed Mar 07, 2018 8:14 am Hi All,
Thanks,
Mike
https://www.ebay.co.uk/itm/A-Pack-20-A4 ... V2vaVeBJMQ
mike_glos
Re: Roof Mount
Post by mike_glos » Wed Mar 07, 2018 1:14 pm
Thanks All. much appreciated
Ahead
Re: Roof Mount
Post by Ahead » Fri Mar 09, 2018 11:11 pm
I got a bag of M8 with hex key head from Screwfix, fitted perfectly. Got loads over if you’re struggling pm me and I’ll see if I can find them..
Re: Roof Mount
Post by Bob » Sat Mar 10, 2018 10:15 am
Useful info, thanks. =D>
mike_glos
Re: Roof Mount
Post by mike_glos » Sat Mar 10, 2018 10:57 pm
Yes to be fair the set of M8s I had already got from ebay did the job:
https://www.ebay.co.uk/itm/M8-8mm%C3%98 ... 2749.l2649
