Fixing seat runners
Razor
Fixing seat runners
Post by Razor » Wed Feb 21, 2018 12:00 am
Well another busy day on the bongo today,insulating,fitting wooden floor and refitting runners and seat belt points, a question to those more experienced on these matters, I have refitted the front runners onto the new floor with new bolts and spacers into the original fixing points my question is do you think this will impact the insurance as the runners are fitted through the wooden floor and therefore will have more flexibility at the anchoring points,
Razor.
Re: Fixing seat runners
Post by Bob » Wed Feb 21, 2018 12:07 am
The only real answer is to declare it as a 'modifaction' and see what they say.
Problem is I doubt they will understand what you've done and either give a flat "No" or load the premium way off the scale. :(
Is this part of a camper conversion which would be a pretty normal mod?
TheLongRoad
Post by TheLongRoad » Wed Feb 21, 2018 11:00 am
As Bob says, anything that is not factory fitted is a modification in the eyes of the insurance world - who will be delighted to reject any future claim. It's not many years ago I was told the fitting of winter tyres on BMW steel wheels by the main BMW dealer would be classified as a modification and I'd have to pay an excess on my premuim. Fortunately things have changed a bit as winter tyres have become more common place.
2002 Friendee 2.0 ltr Petrol.
wonkanoby
Post by wonkanoby » Wed Feb 21, 2018 4:17 pm
drill the wood and fit steel spacers in the hole same depth?
Razor
Post by Razor » Wed Feb 21, 2018 11:02 pm
I have drilled the flooring and fitted spacers the same depth so I will leave it at that,
Thanks one and all.
Razor
Razor
Post by Razor » Thu Feb 22, 2018 9:59 pm
Just a thought as the seat belts are now not in the right position with the seats reversed could the belts be fitted to the front seat mounting points or is there’s an alternative?,thanks in advance,
Razor.
Post by Bob » Thu Feb 22, 2018 10:32 pm
If you've reversed the middle seat there is no requirement for seat belts.
I'm not sure how you would get on fitting two belts to one fixing point, and don't know how you would fix to the bottom point.
