Timing Belt on 2 Litre
Post by Ian » Wed Jan 24, 2018 11:30 am
We have a member with a Bongo stuck in a garage in Galicia, Spain. The alternator belt snapped and then became stuck under the timing belt. No further damage seems to have been caused, but the timing belt now needs re-aligning. The mechanic has been supplied with the relevant information from the workshop manual, but paragraph 2, on page 22, is causing some problems. It it entitled "Cam Shaft Pulley Timing Mark" and states "attach the timing belt in order of the numbers shown in the diagram........".
What numbers? Which diagram?
Re: Timing Belt on 2 Litre
Post by teenmal » Wed Jan 24, 2018 1:07 pm
The cam shaft pulley ( if relevant ) will have markings 1/2/3/4 ,you set TDC to the relevant engine size ( CC number of valves), on that particular engine it could be 2/3.
The mechanic should be able to check that the cam shaft is timed correctly by doing a manual test on the valve positions for that particular pulley setting.
Take Care
Post by Ian » Wed Jan 24, 2018 1:33 pm
You're a star! Will translate and pass it on to Senor Spanners in Galicia!
Hercules
Post by Hercules » Wed Jan 24, 2018 3:10 pm
Thanks for the quick responses. I’ll pass this information on.
Much appreciated
Thanks Very much Ian you have been marvellous
Pauline
Hercules
Post by Hercules » Wed Jan 24, 2018 3:37 pm
Sorry, just to check. This information Is for a 2lt Petrol 2004 model
P
