sevice
oldmanpete
sevice
Post by oldmanpete » Thu Jan 11, 2018 4:28 pm
Where can I get a/the service schedule for a 2.5 derv 1999/2000?
want my LOCAL garage to do it.
Allan's a bit far to go for a regular 6000 mile service.
Re: sevice
Post by Ian » Thu Jan 11, 2018 4:44 pm
Engine Oil 5,000 km or 6 months
Oil Filter 10,000 km or 12 months
Differential Oil 100,000 km
Brake Fluid 2 years
Coolant 2 years
Air Filter 50,000 km
Fuel Filter 50,000 km (although we recommend changing it annually; even more frequently if you are using a veg-oil mix)
Fuel Hose 4 years
Timing Belt 100,000 km
ATF & Filter 2 years
Glow Plugs 50,000 km
Transfer Case Lubricant 50,000 km
In addition, we recommend that you check the following every 6 months:
• Front & rear brake pads
• Clean the fuel line banjo filter
• Check all hoses
• Check the front and rear diff oil levels (just rear if 2WD)
• With a bar go round and check all ball joints
• Visually inspect anti-roll bar bushes and brackets
• Check exhaust
• Clean out drain hole near wipers
Markas
Re: service
Post by Markas » Sat Jan 13, 2018 12:59 am
i believe there are quite a few specialists around Southampton where fresh imports enter the country. A lot of them focus on building camper conversions, but you should be able to find someone to sort you out in that area.
Mark
